A generalized finite element method for problems with sign-changing coefficients - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
Problems with sign-changing coefficients occur, for instance, in the study of transmission problems with metamaterials. In this work, we present and analyze a generalized finite element method in the spirit of the Localized Orthogonal Decomposition, that is especially efficient when the negative and positive materials exhibit multiscale features. We derive optimal linear convergence in the energy norm independently of the potentially low regularity of the exact solution. Numerical experiments illustrate the theoretical convergence rates and show the applicability of the method for a large class of sign-changing diffusion problems.
chaumontfrelet_verfurth_2020a.pdf (1.2 Mo) Télécharger le fichier
hal-02496832 , version 1 (03-03-2020)
hal-02496832 , version 2 (27-08-2020)
Théophile Chaumont-Frelet, Barbara Verfürth. A generalized finite element method for problems with sign-changing coefficients. 2020. ⟨hal-02496832v1⟩
121 Consultations
88 Téléchargements
