Physiological effects of gamma irradiation in the honeybee, Apis mellifera - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Ecotoxicology and Environmental Safety Année : 2019
Terrestrial ecosystems are exposed to various kinds of pollutants, including radionuclides. The honeybee, Apis mellifera, is commonly used in ecotoxicology as a model species for evaluating the effects of pollutants. In the present study, honeybees were irradiated right after birth for 14 days with gamma rays at dose rates ranging between 4.38x10-3 and 588 mGy/d. Biological tissues (head, intestine and abdomen) were sampled at D3, D10 and D14. Ten different physiological markers involved in nervous (acetylcholinesterase (AChE)), antioxidative (catalase (CAT), superoxide dismutase (SOD), glutathione peroxidase (GPx) and glutathione-S-transferase (GST)), immune system (phenoloxidase (PO)) and metabolism (carboxylesterases (CaEs) and alkaline phosphatase (ALP)) were measured. Univariate analyses were conducted to determine whether each individual biomarker response was positively or negatively correlated with the dose rate. Then, multivariate analyses were applied to investigate the relationships between all the biomarker responses. Although no mortality occurred during the experiment, several biomarkers varied significantly in relation to the dose rate. Globally, the biomarkers of antioxidant and immune systems decreased as the dose rate increased. Reversible effects on the indicator of the neural system were found. Concerning indicators of metabolism (carboxylesterases), variations occurred but no clear pattern was found. Taken altogether, these results help better understand the effects of ionizing radiation on bees by identifying relevant physiological markers of effects. These results could improve the assessment of the environmental risk due to ionizing radiation in terrestrial ecosystems.
0000164759_002.PDF (2.35 Mo) Télécharger le fichier
hal-02501469 , version 1 (06-03-2020)
Paternité - Pas d'utilisation commerciale - Pas de modification
Beatrice Gagnaire, M Bonnet, S Tchamitchian, Isabelle Cavalie, Claire Della-Vedova, et al.. Physiological effects of gamma irradiation in the honeybee, Apis mellifera. Ecotoxicology and Environmental Safety, 2019, 174, pp.153-163. ⟨10.1016/j.ecoenv.2019.02.031⟩. ⟨hal-02501469⟩
45 Consultations
151 Téléchargements
