On the compatibility of the adiabatic and rotating wave approximations for robust population transfer in qubits - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
In the physics literature it is common to see the rotating wave approximation and the adiabatic approximation used "in cascade" to justify the use of chirped pulses for two-level quantum systems driven by one external field, in particular when the resonance frequency of the system is not known precisely. Both approximations need relatively long time and are essentially based on averaging theory of dynamical systems. Unfortunately, the two approximations cannot be done independently since, in a sense, the two time scales interact. The purpose of this paper is to study how the cascade of the two approximations can be justified and how large becomes the final time as the fidelity goes to one, while preserving the robustness of the adiabatic strategy. Our main result gives a precise quantification of the uncertainty interval of the resonance frequency for which the strategy works. We believe that this result, beside its mathematical interest, could be useful in experimental situations.
paper.pdf (661.08 Ko) Télécharger le fichier
hal-02504532 , version 1 (10-03-2020)
hal-02504532 , version 2 (10-05-2021)
  • HAL Id : hal-02504532 , version 1
Rémi Robin, Nicolas Augier, Ugo Boscain, Mario Sigalotti. On the compatibility of the adiabatic and rotating wave approximations for robust population transfer in qubits. 2020. ⟨hal-02504532v1⟩
472 Consultations
225 Téléchargements
