Direct Radiative Effect by Mineral Dust Aerosols Constrained by New Microphysical and Spectral Optical Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Geophysical Research Letters Année : 2020
We revise the direct radiative effect (DRE) of mineral dust aerosols in the shortwave (SW) and longwave (LW) based on global model simulations that include coarse dust particles (>20 μm) and a new LW complex refractive index data set representative of major global sources. Simulations are constrained against observed dust size distributions and optical depth. Scattering of LW radiation is accounted for in the analysis. The extension of the dust size beyond 20 μm causes a reduction in the SW DRE compared to current model estimates, while the LW DRE remains within published values due to compensating effects between changing size distribution, complex refractive index, and accounting for dust scattering. The dust direct radiative effect efficiency from model simulations reproduces well field observations close to sources and after transport. The global mean net effect of dust is −0.03 Wm −2 as a result of cooling over oceans and warming over land.
GRL_DiBiagio_manuscript_2020.pdf (1014.12 Ko) Télécharger le fichier
hal-02505450 , version 1 (03-04-2020)
Claudia Di Biagio, Yves Balkanski, Samuel Albani, O. Boucher, P. Formenti. Direct Radiative Effect by Mineral Dust Aerosols Constrained by New Microphysical and Spectral Optical Data. Geophysical Research Letters, 2020, 47 (2), ⟨10.1029/2019GL086186⟩. ⟨hal-02505450⟩
153 Consultations
278 Téléchargements
