Towards Proactive Navigation: A Pedestrian-Vehicle Cooperation Based Behavioral Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Developing autonomous vehicles capable of navigating safely and socially around pedestrians is a major challenge in intelligent transportation. This challenge cannot be met without understanding pedestrians' behavioral response to an autonomous vehicle, and the task of building a clear and quantitative description of the pedestrian to vehicle interaction remains a key milestone in autonomous navigation research. As a step towards safe proactive navigation in a space shared with pedestrians, this work introduces a pedestrian-vehicle interaction behavioral model. The model estimates the pedestrian's cooperation with the vehicle in an interaction scenario by a quantitative time-varying function. Using this cooperation estimation the pedestrian's trajectory is predicted by a cooperation-based trajectory planning model. Both parts of the model are tested and validated using real-life recorded scenarios of pedestrian-vehicle interaction. The model is capable of describing and predicting agents' behaviors when interacting with a vehicle in both lateral and frontal crossing scenarios.
ICRA20202_Kabtoul_Spalanzani_Martinet.pdf (3.48 Mo) Télécharger le fichier
hal-02509637 , version 1 (17-03-2020)
  • HAL Id : hal-02509637 , version 1
Maria Kabtoul, Anne Spalanzani, Philippe Martinet. Towards Proactive Navigation: A Pedestrian-Vehicle Cooperation Based Behavioral Model. ICRA 2020 - IEEE International Conference on Robotics and Automation, May 2020, Paris, France. pp.6958-6964. ⟨hal-02509637⟩
308 Consultations
223 Téléchargements
