Structural Requirements for Digital Transformation – Insights from German Enterprises - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Matthias Murawski
  • Fonction : Auteur
  • PersonId : 1027693
Tristan Thordsen
  • Fonction : Auteur
  • PersonId : 1066440
Malte Martensen
  • Fonction : Auteur
  • PersonId : 1066441
Christina Rademacher
  • Fonction : Auteur
  • PersonId : 1066442
Markus Bick
  • Fonction : Auteur
  • PersonId : 985663
German enterprises are often characterised by low levels of digital maturity. One reason for this is a lack of required structural changes on the path towards digital transformation. We consider a prescriptive framework, the digital transformation framework (DTF), which contains four structural requirements for digital transformation. Based on 16 interviews with German digitalisation experts, we aim at an evaluation of the DTF. The outcome is an enriched version of it containing seven structural requirements including the newly identified factors culture of change, agility of organizational structure, and integration of cloud computing and platforms. The extended DTF sheds light on additional facets of the digital transformation and thus supports managers in navigating their undertaking in this dynamic environment. Corresponding implications for research and practice are discussed.
I3E2019_paper_97.pdf (234.88 Ko) Télécharger le fichier
hal-02510117 , version 1 (17-03-2020)
Paternité
Matthias Murawski, Tristan Thordsen, Malte Martensen, Christina Rademacher, Markus Bick. Structural Requirements for Digital Transformation – Insights from German Enterprises. 18th Conference on e-Business, e-Services and e-Society (I3E), Sep 2019, Trondheim, Norway. pp.718-729, ⟨10.1007/978-3-030-29374-1_58⟩. ⟨hal-02510117⟩
72 Consultations
126 Téléchargements
