Construction of a two-phase flow with singular energy by gradient flow methods - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Differential Equations Année : 2023
We prove the existence of weak solutions to a system of two diffusion equations that are coupled by a pointwise volume constraint. The time evolution is given by gradient dynamics for a free energy functional. Our primary example is a model for the demixing of polymers, the corresponding energy is the one of Flory, Huggins and de Gennes. Due to the non-locality in the equations, the dynamics considered here is qualitatively different from the one found in the formally related Cahn-Hilliard equations. Our angle of attack is from the theory of optimal mass transport, that is, we consider the evolution equations for the two components as two gradient flows in the Wasserstein distance with one joint energy functional that has the volume constraint built in. The main difference to our previous work [C. Canc\`es, D. Matthes & F. Nabet, Arch. Ration. Mech. Anal., 233:837–866, 2019] is the nonlinearity of the energy density in the gradient part, which becomes singular at the interface between pure and mixed phases, leading to new theoretical difficulties.
TwoPhaseSingular-rev.pdf (401.72 Ko) Télécharger le fichier
hal-02510535 , version 1 (17-03-2020)
hal-02510535 , version 2 (08-11-2022)
Clément Cancès, Daniel Matthes. Construction of a two-phase flow with singular energy by gradient flow methods. Journal of Differential Equations, 2023, 344, pp.439-470. ⟨10.1016/j.jde.2022.11.010⟩. ⟨hal-02510535v2⟩
339 Consultations
112 Téléchargements
