Temporal Refinements for Guarded Recursive Types - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
Colin Riba
  • Fonction : Auteur
  • PersonId : 938059
We propose a logic to reason on temporal properties of higher-order programs that handle infinite objects like streams or infinite trees, represented via coinductive types. Specifications of programs are defined using safety and liveness properties. A given program can then be proven to satisfy its specification, in a compositional way, our logic being based on a type system. The logic is presented as a refinement type system over the guarded lambda-calculus, a λ-calculus with guarded recursive types. The refinements are formulae of a modal μ-calculus which embeds usual temporal modal logics such as LTL and CTL. The semantics of our system is given within a rich structure, the topos of trees, in which we build a realizability model of the temporal refinement type system. We use in a crucial way the connection with set-theoretic semantics to handle liveness properties.
reftrees.pdf (1.28 Mo) Télécharger le fichier
hal-02512655 , version 1 (19-03-2020)
hal-02512655 , version 2 (16-07-2020)
hal-02512655 , version 3 (07-01-2021)
hal-02512655 , version 4 (21-01-2021)
hal-02512655 , version 5 (14-03-2021)
  • HAL Id : hal-02512655 , version 2
Guilhem Jaber, Colin Riba. Temporal Refinements for Guarded Recursive Types. 2020. ⟨hal-02512655v2⟩
394 Consultations
272 Téléchargements
