Deterministic Approximate EM Algorithm; Application to the Riemann Approximation EM and the Tempered EM - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2022
The Expectation Maximisation (EM) algorithm is widely used to optimise non-convex likelihood functions with latent variables. Many authors modified its simple design to fit more specific situations. For instance, the Expectation (E) step has been replaced by Monte Carlo (MC), Markov Chain Monte Carlo or tempered approximations... Most of the well-studied approximations belong to the stochastic class. By comparison, the literature is lacking when it comes to deterministic approximations. In this paper, we introduce a theoretical framework, with state-of-the-art convergence guarantees, for any deterministic approximation of the E step. We analyse theoretically and empirically several approximations that fit into this framework. First, for intractable E-steps, we introduce a deterministic version of MC-EM using Riemann sums. A straightforward method, not requiring any hyper-parameter fine-tuning, useful when the low dimensionality does not warrant a MC-EM. Then, we consider the tempered approximation, borrowed from the Simulated Annealing literature and used to escape local extrema. We prove that the tempered EM verifies the convergence guarantees for a wider range of temperature profiles than previously considered. We showcase empirically how new non-trivial profiles can more successfully escape adversarial initialisations. Finally, we combine the Riemann and tempered approximations into a method that accomplishes both their purposes.
main.pdf (843.5 Ko) Télécharger le fichier
Algorithms.zip (5.89 Mo) Télécharger le fichier
supplements.pdf (2.18 Mo) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-02513593 , version 1 (20-03-2020)
hal-02513593 , version 2 (18-12-2020)
hal-02513593 , version 3 (03-02-2022)
hal-02513593 , version 4 (02-05-2022)
Thomas Lartigue, Stanley Durrleman, Stéphanie Allassonnière. Deterministic Approximate EM Algorithm; Application to the Riemann Approximation EM and the Tempered EM. 2022. ⟨hal-02513593v3⟩
357 Consultations
628 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
