Free boundary limit of tumor growth model with nutrient - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal de Mathématiques Pures et Appliquées Année : 2021
Both compressible and incompressible porous medium models are used in the literature to describe the mechanical properties of living tissues. These two classes of models can be related using a stiff pressure law. In the incompressible limit, the compressible model generates a free boundary problem of Hele-Shaw type where incompressibility holds in the saturated phase. Here we consider the case with a nutrient. Then, a badly coupled system of equations describes the cell density number and the nutrient concentration. For that reason, the derivation of the free boundary (incompressible) limit was an open problem, in particular a difficulty is to establish the so-called complementarity relation which allows to recover the pressure using an elliptic equation. To establish the limit, we use two new ideas. The first idea, also used recently for related problems, is to extend the usual Aronson-Bénilan estimates in $L^\infty$ to an $L^2$ setting. The second idea is to derive a sharp uniform $L^4$ estimate on the pressure gradient, independently of space dimension.
David_Perthame_Free_boundary_limit.pdf (406 Ko) Télécharger le fichier
hal-02515263 , version 1 (23-03-2020)
hal-02515263 , version 2 (06-05-2020)
hal-02515263 , version 3 (24-06-2020)
Noemi David, Benoît Perthame. Free boundary limit of tumor growth model with nutrient. Journal de Mathématiques Pures et Appliquées, 2021, 155, pp.62-82. ⟨10.1016/j.matpur.2021.01.007⟩. ⟨hal-02515263v3⟩
486 Consultations
351 Téléchargements
