Open-Source 4G Experimental Setup - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this work, we show how to set up a cellular LTE network for wireless experimentation and measurement, relying on commodity hardware and open-source software. We first deploy a complete LTE network on a single laptop and an SDR hardware. Then, we use it to evaluate the reception performance of a commercial smartphone. In the end, we propose a calibration technique which allows using a smartphone as a wireless power measurement tool by reducing the root-mean-square error of the RSSI, with respect to a reference power measured with a specialized spectrum analyzer, from 6.4 dBm to 2.4 dBm.
Open-Source 4G Experimental Setup.pdf (416.13 Ko) Télécharger le fichier
hal-02515793 , version 1 (08-02-2021)
Yanis Boussad, Arnaud Legout, Walid Dabbous, Leonardo Lizzi, Fabien Ferrero, et al.. Open-Source 4G Experimental Setup. 2020 IEEE International Symposium on Antennas and Propagation and North American Radio Science Meeting, IEEE, Jul 2020, Montreal, Canada. pp.1399-1400, ⟨10.1109/IEEECONF35879.2020.9330245⟩. ⟨hal-02515793⟩
198 Consultations
125 Téléchargements
