Using computed infrared intensities for fast computation of vibrational spectra - Archive ouverte HAL Access content directly
Preprints, Working Papers, ... Year :
(1) , (1) , (1) , (1) , (2)
1
2
The Adaptive Vibrational Configuration Interaction (A-VCI) algorithm is an iterative pro-cess able to compute the spectrum of an Hamiltonian operator, using a discretization basisas small as possible. In this work, we show how this algorithm can handle more sophis-ticated operators, which ro-vibrational Coriolis coupling terms. In order to overcome theincrease of computing and storage resources needed due to this enrichment, the InfraRed(IR) intensities are computed and used as a criterion to select only the eigenstates corre-sponding to IR active vibrational states. The benefits of this new approach are presentedfor a few well studied molecular systems (H2O, H2CO, CH2NH, CH3CN, C2H4O), and itis ultimately applied to a 10-atom molecule (C4H4N2)
avci3.pdf (430.98 Ko) Télécharger le fichier
Dates and versions
hal-02518243 , version 1 (25-03-2020)
Identifiers
  • HAL Id : hal-02518243 , version 1
Cite
Vincent Le Bris, Marc Odunlami, Didier Bégué, Isabelle Baraille, Olivier Coulaud. Using computed infrared intensities for fast computation of vibrational spectra. 2019. ⟨hal-02518243⟩
71 View
338 Download
Share
