φ-FEM, a finite element method on domains defined by level-sets: the Neumann boundary case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
We extend a fictitious domain-type finite element method, called φ-FEM and introduced in [7], to the case of Neumann boundary conditions. The method is based on a multiplication by the level-set function and does not require a boundary fitted mesh. Unlike other recent fictitious domain-type methods (XFEM, CutFEM), our approach does not need any non-standard numerical integration on cut mesh elements or on the actual boundary. We prove the optimal convergence of φ-FEM and the fact that the discrete problem is well conditioned inependently of the mesh cuts. The numerical experiments confirm the theoretical results.
main.pdf (826.84 Ko) Télécharger le fichier
hal-02521042 , version 1 (27-03-2020)
hal-02521042 , version 2 (13-11-2020)
hal-02521042 , version 3 (11-01-2022)
  • HAL Id : hal-02521042 , version 1
Michel Duprez, Vanessa Lleras, Alexei Lozinski. φ-FEM, a finite element method on domains defined by level-sets: the Neumann boundary case. 2020. ⟨hal-02521042v1⟩
605 Consultations
453 Téléchargements
