Digital implementation of sliding-mode control via the implicit method: A tutorial - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
The objective of this article, is to provide a clear presentation of the discretization of continuous-time sliding-mode controllers, also known in the Automatic Control literature as the emulation method, when the implicit (backward) Euler scheme is used. First-order, second-order and homogeneous controllers are considered. The main theoretical results are recalled in each case, and the focus is put on the discrete-time implementation structure and on the algorithms which allow the designer to solve, at each time-step, the one-step generalized equations which are needed to compute the controllers. The article ends with some open issues.
BB-AP-IJRNC.pdf (1.06 Mo) Télécharger le fichier
hal-02523011 , version 1 (28-03-2020)
hal-02523011 , version 2 (11-08-2020)
  • HAL Id : hal-02523011 , version 1
Bernard Brogliato, Andrey Polyakov. Digital implementation of sliding-mode control via the implicit method: A tutorial. 2020. ⟨hal-02523011v1⟩
311 Consultations
1071 Téléchargements
