Turbulent flows as generalized Kelvin-Voigt materials: modeling and analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nonlinear Analysis: Theory, Methods and Applications Année : 2020
We model a 3D turbulent fluid, evolving toward a statistical equilibrium, by adding to the equations for the mean field (v, p) a term like $−α∇ · ((x)Dv t)$, which is of the Kelvin-Voigt form, where the Prandtl mixing length is not constant and vanishes at the solid walls. We get estimates for velocity v in $L ∞ t H 1 x ∩ W 1,2 t H 1/2 x$ , that allow us to prove the existence and uniqueness of a regular-weak solutions (v, p) to the resulting system, for a given fixed eddy viscosity. We then prove a structural compactness result that highlights the robustness of the model. This allows us to pass to the limit in the quadratic source term in the equation for the turbulent kinetic energy k, which yields the existence of a weak solution to the corresponding RANS system satisfied by (v, p, k).
Generalized_Voigt-V6.pdf (435 Ko) Télécharger le fichier
hal-02523938 , version 1 (29-03-2020)
Chérif Amrouche, Luigi C. Berselli, Roger Lewandowski, Dinh Duong Nguyen. Turbulent flows as generalized Kelvin-Voigt materials: modeling and analysis. Nonlinear Analysis: Theory, Methods and Applications, 2020, 196, pp.1-27. ⟨10.1016/j.na.2020.111790⟩. ⟨hal-02523938⟩
202 Consultations
140 Téléchargements
