Cross-modal Deep Face Normals with Deactivable Skip Connections - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present an approach for estimating surface normals from in-the-wild color images of faces. While datadriven strategies have been proposed for single face images, limited available ground truth data makes this problem difficult. To alleviate this issue, we propose a method that can leverage all available image and normal data, whether paired or not, thanks to a novel cross-modal learning architecture. In particular, we enable additional training with single modality data, either color or normal, by using two encoder-decoder networks with a shared latent space. The proposed architecture also enables face details to be transferred between the image and normal domains, given paired data, through skip connections between the image encoder and normal decoder. Core to our approach is a novel module that we call deactivable skip connections, which allows integrating both the auto-encoded and imageto-normal branches within the same architecture that can be trained end-to-end. This allows learning of a rich latent space that can accurately capture the normal information. We compare against state-of-the-art methods and show that our approach can achieve significant improvements, both quantitative and qualitative, with natural face images.
abrevaya-et-al__cvpr-20.pdf (1.95 Mo) Télécharger le fichier
hal-02525049 , version 1 (30-03-2020)
Victoria Fernández Abrevaya, Adnane Boukhayma, Philip H. S. Torr, Edmond Boyer. Cross-modal Deep Face Normals with Deactivable Skip Connections. CVPR 2020 - IEEE Conference on Computer Vision and Pattern Recognition, Jun 2020, Seattle, United States. pp.4978-4988, ⟨10.1109/CVPR42600.2020.00503⟩. ⟨hal-02525049⟩
415 Consultations
444 Téléchargements
