Full-waveform redatuming via a TRAC approach: a first step towards target oriented inverse problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2021
In inverse problems, redatuming data consists in virtually moving thesensors from the original acquisition location to an arbitrary position. Thisis an essential tool for target oriented inversion. An exact redatumingmethod which has the peculiarity to be robust with respect to noise isproposed. Our iterative method is based on the Time Reversal AbsorbingConditions (TRAC) approach and avoids the need for a regularization strategy. Numerical results and comparisons with other redatumingapproaches illustrate the robustness of our method.
article.pdf (12.67 Mo) Télécharger le fichier
hal-02530264 , version 1 (02-04-2020)
hal-02530264 , version 2 (02-01-2021)
  • HAL Id : hal-02530264 , version 2
Franck Assous, Frédéric Nataf. Full-waveform redatuming via a TRAC approach: a first step towards target oriented inverse problem. Journal of Computational Physics, 2021, 440. ⟨hal-02530264v2⟩
126 Consultations
29 Téléchargements
