Further Results on an Equitable 1-2-3 Conjecture - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2020
In this work, we consider equitable proper labellings of graphs, which were recently introduced by Baudon, Pilśniak, Przybyƚo, Senhaji, Sopena, and Wozńiak. Given a graph G, the goal is to assign labels to the edges so that 1) no two adjacent vertices are incident to the same sum of labels, and 2) every two labels are assigned about the same number of times. Particularly , we aim at designing such equitable proper k-labellings of G with k being as small as possible. In connection with the so-called 1-2-3 Conjecture, it might be that labels 1,2,3 are, a few obvious exceptions apart, always sufficient to achieve this just as in the non-equitable version of the problem. We provide results regarding some open questions about equitable proper labellings. Via a hardness result, we first prove that there exist infinitely many graphs for which more labels are required in the equitable version than in the non-equitable version. This remains true in the bipartite case. We finally show that, for every $k≥3$, every k-regular bipartite graph admits an equitable proper k-labelling.
equitable123.pdf (522.63 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-02533537 , version 1 (06-04-2020)
hal-02533537 , version 2 (02-02-2021)
hal-02533537 , version 3 (21-02-2022)
  • HAL Id : hal-02533537 , version 1
Julien Bensmail, Foivos Fioravantes, Fionn Mc Inerney, Nicolas Nisse. Further Results on an Equitable 1-2-3 Conjecture. [Research Report] Université Côte d'Azur, CNRS, I3S, France; Inria Sophia Antipolis; Aix-Marseille Université (AMU). 2020. ⟨hal-02533537v1⟩
Collections
LARA
310 Consultations
188 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
