Ancestral Genome Organization as a Diagnosis Tool for Phylogenomics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2020
The reconstruction of the chromosomal organization of ancient genomes has many applications in comparative and evolutionary genomics. Here we propose a novel, methodological, use for these predicted ancestral syntenies, directly focused on phylogenomics. It is a way to assess the accuracy of gene trees and species trees. We use a method that reconstructs, from gene trees and extant gene orders, ancestral adjacencies, i.e. the immediate neighborhood between pairs of genes, independently for each pair. This independence allows to split the computations into many independent problems that can each be solved exactly using efficient algorithms, but might result in sets of ancestral adjacencies that are incompatible with the expected linear or circular structure of chromosomes. We show here that this drawback can actually be turned into a useful 1 This work benefited from the support of ComputeCanada.
chapter_2.5_chauve.pdf (2.24 Mo) Télécharger le fichier
hal-02535466 , version 1 (10-04-2020)
Paternité - Pas d'utilisation commerciale - Pas de modification
  • HAL Id : hal-02535466 , version 1
Eric Tannier, Adelme Bazin, Adrián Davín, Laurent Guéguen, Sèverine Bérard, et al.. Ancestral Genome Organization as a Diagnosis Tool for Phylogenomics. Scornavacca, Celine; Delsuc, Frédéric; Galtier, Nicolas. Phylogenetics in the Genomic Era, No commercial publisher | Authors open access book, pp.2.5:1--2.5:19, 2020. ⟨hal-02535466⟩
655 Consultations
228 Téléchargements
