Stability and Convergence Analysis of Time-domain Perfectly Matched Layers for The Wave Equation in Waveguides - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Numerical Analysis Année : 2021
This work is dedicated to the proof of stability and convergence of the Bérenger's perfectly matched layers in the waveguides for an arbitrary L ∞ damping function. The proof relies on the Laplace domain techniques and an explicit representation of the solution to the PML problem in the waveguide. A bound for the PML error that depends on the absorption parameter and the length of the PML is presented. Numerical experiments confirm the theoretical findings.
main_preprint.pdf (488.55 Ko) Télécharger le fichier
erratum (1).pdf (24.11 Ko) Télécharger le fichier
hal-02536375 , version 1 (08-04-2020)
Eliane Bécache, Maryna Kachanovska. Stability and Convergence Analysis of Time-domain Perfectly Matched Layers for The Wave Equation in Waveguides. SIAM Journal on Numerical Analysis, 2021, ⟨10.1137/20M1330543⟩. ⟨hal-02536375⟩
155 Consultations
243 Téléchargements
