Dynamics of the Schrödinger-Langevin equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nonlinearity Année : 2021
We consider the nonlinear Schrödinger-Langevin equation for both signs of the logarithmic nonlinearity. We explicitly compute the dynamics of Gaussian solutions for large times, which is obtained through the study of a particular nonlinear differential equation of order 2. We then give the asymptotic behavior of general energy weak solutions under some regularity assumptions. Some numerical simulations are performed in order to corroborate the theoretical results.
dynamique_gaussienne.pdf (645.4 Ko) Télécharger le fichier
hal-02541831 , version 1 (14-04-2020)
Quentin Chauleur. Dynamics of the Schrödinger-Langevin equation. Nonlinearity, 2021, 34 (4), pp.1943-1974. ⟨10.1088/1361-6544/abd528⟩. ⟨hal-02541831⟩
351 Consultations
399 Téléchargements
