On the Exponential decay for Compressible Navier-Stokes-Korteweg equations with a Drag Term - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Mathematical Fluid Mechanics Année : 2022
In this paper, we consider global weak solutions to com-pressible Navier-Stokes-Korteweg equations with density dependent viscosities , in a periodic domain $\Omega = \mathbb T^3$, with a linear drag term with respect to the velocity. The main result concerns the exponential decay to equilibrium of such solutions using log-sobolev type inequalities. In order to show such a result, the starting point is a global weak-entropy solutions definition introduced in D. Bresch, A. Vasseur and C. Yu [12]. Assuming extra assumptions on the shear viscosity when the density is close to vacuum and when the density tends to infinity, we conclude the exponential decay to equilibrium. Note that our result covers the quantum Navier-Stokes system with a drag term.
2020_07_10.pdf (180.42 Ko) Télécharger le fichier
hal-02542115 , version 1 (14-04-2020)
hal-02542115 , version 2 (10-07-2020)
Didier Bresch, Marguerite Gisclon, Ingrid Lacroix-Violet, Alexis F. Vasseur. On the Exponential decay for Compressible Navier-Stokes-Korteweg equations with a Drag Term. Journal of Mathematical Fluid Mechanics, 2022, 24 (11), ⟨10.1007/s00021-021-00639-2⟩. ⟨hal-02542115v2⟩
106 Consultations
163 Téléchargements
