Enhanced Vertical Mixing in Coastal Upwelling Systems Driven by Diurnal‐Inertial Resonance: Numerical Experiments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Geophysical Research. Oceans Année : 2020
The land-sea breeze is resonant with the inertial response of the ocean at the critical latitude of 30 degrees N/S. 1-D vertical numerical experiments were undertaken to study the key drivers of enhanced diapycnal mixing in coastal upwelling systems driven by diurnal-inertial resonance near the critical latitude. The effect of the land boundary was implicitly included in the model through the "Craig approximation" for first-order cross-shore surface elevation gradient response. The model indicates that for shallow water depths (
2020JC016208.pdf (17.37 Mo) Télécharger le fichier
hal-02544118 , version 2 (16-04-2020)
hal-02544118 , version 1 (08-10-2021)
Giles Fearon, Steven Herbette, Jennifer Veitch, Gildas Cambon, Andrew Lucas, et al.. Enhanced Vertical Mixing in Coastal Upwelling Systems Driven by Diurnal‐Inertial Resonance: Numerical Experiments. Journal of Geophysical Research. Oceans, 2020, 125 (9), ⟨10.1029/2020JC016208⟩. ⟨hal-02544118v1⟩
151 Consultations
335 Téléchargements
