Does the Pop-Out Make an Effect in the Product Selection of Signage Vending Machine? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Mitsuki Hosoya
  • Fonction : Auteur
  • PersonId : 1068180
Makoto Nakamura
  • Fonction : Auteur
Eiji Takamatsu
  • Fonction : Auteur
Yujiro Kitaide
  • Fonction : Auteur
When people select a product, they often face problems that they spend too much time to make a choice or tend to pick only popular items. As a solution to this problem, we focused on visual characteristics called pop-out, assuming that presenting the pop-out can lead to shortening the selection time and a wider variety of choice. In this study, we implemented a signage vending machine which had a pop-out function and conducted a long-term experiment (half year) to investigate the effect of the pop-out method in a real environment. From 2826 sales, we revealed that the selection time was short when the purchased items were popped-out, and a popped-out product was more likely to be selected by 1.51 times than chance level during the cold-only period that sold cold products only. On the other hand, there was no effect of the pop-out during the hot/cold mixed period that sold both cold and hot products.
488591_1_En_2_Chapter.pdf (2.08 Mo) Télécharger le fichier
hal-02544611 , version 1 (16-04-2020)
Paternité
Mitsuki Hosoya, Hiroaki Yamaura, Satoshi Nakamura, Makoto Nakamura, Eiji Takamatsu, et al.. Does the Pop-Out Make an Effect in the Product Selection of Signage Vending Machine?. 17th IFIP Conference on Human-Computer Interaction (INTERACT), Sep 2019, Paphos, Cyprus. pp.24-32, ⟨10.1007/978-3-030-29384-0_2⟩. ⟨hal-02544611⟩
35 Consultations
37 Téléchargements
