Gradient discretization of two-phase flows coupled with mechanical deformation in fractured porous media - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Preprints, Working Papers, ... Year : 2020
We consider a two-phase Darcy flow in a fractured porous medium consisting in a matrix flow coupled with a tangential flow in the fractures, described as a network of planar surfaces. This flow model is also coupled with the mechanical deformation of the matrix assuming that the fractures are open and filled by the fluids, as well as small deformations and a linear elastic constitutive law. The model is discretized using the gradient discretization method [20], which covers a large class of conforming and non conforming schemes. This framework allows for a generic convergence analysis of the coupled model using a combination of discrete functional tools. Here, we describe the model together with its numerical discretization, and we prove a convergence result. This is, to our knowledge, the first convergence result for this type of models taking into account two-phase flows and the non-linear poromechanical coupling. Previous related works consider a linear approximation obtained for a single phase flow by freezing the fracture conductivity [29, 30]. Numerical tests employing the Two-Point Flux Approximation (TPFA) finite volume scheme for the flows and P2 finite elements for the mechanical deformation are also provided to illustrate the behavior of the solution to the model.
GDM_Paper_new_kb.pdf (2.06 Mo) Télécharger le fichier
Dates and versions
hal-02549111 , version 1 (21-04-2020)
hal-02549111 , version 2 (30-11-2020)
hal-02549111 , version 3 (15-07-2021)
Identifiers
  • HAL Id : hal-02549111 , version 2
Cite
Francesco Bonaldi, Konstantin Brenner, Jérôme Droniou, Roland Masson. Gradient discretization of two-phase flows coupled with mechanical deformation in fractured porous media. 2020. ⟨hal-02549111v2⟩
239 View
116 Download
Share
