Universal equivalence and majority of probabilistic programs over finite fields - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2020
We study decidability problems for equivalence of probabilistic programs, for a core probabilistic programming language over finite fields of fixed characteristic. The programming language supports uniform sampling, addition, multiplication and conditionals and thus is sufficiently expressive to encode boolean and arithmetic circuits. We consider two variants of equivalence: the first one considers an interpretation over a fixed finite field, while the second one, which we call universal equivalence, verifies equivalence over all extensions of a finite field. The universal variant typically arises in provable cryptography when one wishes to prove equivalence for any length of bitstrings, i.e., elements of extensions of the boolean field. While the first problem is obviously decidable, we establish its exact complexity which lies in the counting hierarchy. To show decidability, and a doubly exponential upper bound, of the universal variant we rely on results from algorithmic number theory and the possibility to compare local zeta functions associated to given polynomials. Finally we study several variants of the equivalence problem, including a problem we call majority, motivated by differential privacy.
report.pdf (669.49 Ko) Télécharger le fichier
hal-02552287 , version 1 (23-04-2020)
hal-02552287 , version 2 (13-11-2020)
  • HAL Id : hal-02552287 , version 1
Gilles Barthe, Charlie Jacomme, Steve Kremer. Universal equivalence and majority of probabilistic programs over finite fields. [Research Report] MPI SP; LSV, ENS Cachan, CNRS, INRIA, Université Paris-Saclay, Cachan (France); LORIA, UMR 7503, Université de Lorraine, CNRS, Vandoeuvre-lès-Nancy. 2020. ⟨hal-02552287v1⟩
168 Consultations
220 Téléchargements
