Boundary stabilization in finite time of one-dimensional linear hyperbolic balance laws with coefficients depending on time and space - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Differential Equations Année : 2021
In this article we are interested in the boundary stabilization in finite time of one-dimensional linear hyperbolic balance laws with coefficients depending on time and space. We extend the so called ``backstepping method'' by introducing appropriate time-dependent integral transformations in order to map our initial system to a new one which has desired stability properties. The kernels of the integral transformations involved are solutions to non standard multi-dimensional hyperbolic PDEs, where the time dependence introduces several new difficulties in the treatment of their well-posedness. This work generalizes previous results of the literature, where only time-independent systems were considered.
hyperbolic-time-dep.pdf (715.45 Ko) Télécharger le fichier
hal-02553027 , version 1 (24-04-2020)
Jean-Michel Coron, Long Hu, Guillaume Olive, Peipei Shang. Boundary stabilization in finite time of one-dimensional linear hyperbolic balance laws with coefficients depending on time and space. Journal of Differential Equations, 2021, 271, pp.1109-1170. ⟨10.1016/j.jde.2020.09.037⟩. ⟨hal-02553027⟩
154 Consultations
105 Téléchargements
