Is Bigger Better? A Fitts’ Law Study on the Impact of Display Size on Touch Performance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Corinna List
  • Fonction : Auteur
  • PersonId : 1068655
Michael Kipp
  • Fonction : Auteur
  • PersonId : 1005026
Touch-sensitive surfaces are already a standard form of interaction. These surfaces come in many different sizes like tablets or touch walls. However, there is little research to characterize the impact of surface size on touch performance. We conducted a Fitts’ Law study of three display sizes (13.5" tablet, 28" monitor, 69.5" large monitor), comparing various performance measures. We found that the smallest size (13.5" is problematic both objectively (high error rate) and subjectively (imprecise, difficult-to-use). In contrast, both the medium (28") and the large display (69.5") perform equally well. However, small displays allow for greater interaction speed compared to very large screens. Our results can help interaction designers and automatic algorithms to optimize current and future touch devices.
488593_1_En_39_Chapter.pdf (965.58 Ko) Télécharger le fichier
hal-02553877 , version 1 (24-04-2020)
Paternité
Corinna List, Michael Kipp. Is Bigger Better? A Fitts’ Law Study on the Impact of Display Size on Touch Performance. 17th IFIP Conference on Human-Computer Interaction (INTERACT), Sep 2019, Paphos, Cyprus. pp.669-678, ⟨10.1007/978-3-030-29387-1_39⟩. ⟨hal-02553877⟩
39 Consultations
110 Téléchargements
