Optimization of P2 meshes and applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer-Aided Design Année : 2020
Mesh optimization techniques are a way to locally modify the mesh in order to improve it with respect to a given quality criterion. To this end, this work presents the generalization of two mesh quality-based optimization operators to P2 meshes. The generalized operators consist in mesh smoothing and generalized swapping. With the use of these operators, P2 mesh generation starting from a P1 mesh is more robust and P2 connectivity-change moving mesh methods for large displacements are now possible.
CAD-2020.pdf (13.75 Mo) Télécharger le fichier
hal-02554187 , version 1 (25-04-2020)
Rémi Feuillet, Adrien Loseille, Frédéric Alauzet. Optimization of P2 meshes and applications. Computer-Aided Design, 2020, 124, pp.102846. ⟨10.1016/j.cad.2020.102846⟩. ⟨hal-02554187⟩
68 Consultations
138 Téléchargements
