Combined effects of alpha particles and depleted uranium on Zebrafish (Danio rerio) embryos - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Radiation Research Année : 2016
The combined effects of low-dose or high-dose alpha particles and depleted uranium (DU) in Zebrafish (Danio rerio) embryos were studied. Three schemes were examined-(i) [ILUL] 0.44 mGy alpha-particle dose + 10 μg/l DU exposure, (ii) [IHUH] 4.4 mGy alpha-particle dose + 100 μg/l DU exposure and (iii) [IHUL] 4.4 mGy alpha-particle dose + 10 μg/l DU exposure-in which Zebrafish embryos were irradiated with alpha particles at 5 h post fertilization (hpf) and/or exposed to uranium at 5-6 hpf. The results were also compared with our previous work, which studied the effects of [ILUH] 0.44 mGy alpha-particle dose + 100 μg/l DU exposure. When the Zebrafish embryos developed to 24 hpf, the apoptotic signals in the entire embryos, used as the biological endpoint for this study, were quantified. Our results showed that [ILUL] and [IHUL] led to antagonistic effects, whereas [IHUH] led to an additive effect. The effect found for the previously studied case of [ILUH] was difficult to define because it was synergistic with reference to the 100 μg/l DU exposure, but it was antagonistic with reference to the 0.44 mGy alpha-particle dose. All the findings regarding the four different schemes showed that the combined effects critically depended on the dose response to each individual stressor. We also qualitatively explained these findings in terms of promotion of early death of cells predisposed to spontaneous transformation by alpha particles, interacting with the delay in cell death resulting from various concentrations of DU exposure. © 2016 The Author 2016. Published by Oxford University Press on behalf of The Japan Radiation Research Society and Japanese Society for Radiation Oncology.
hal-02558457 , version 1 (29-04-2020)
C.Y.P. Ng, S. Pereira, S.H. Cheng, C. Adam-Guillermin, J. Garnier-Laplace, et al.. Combined effects of alpha particles and depleted uranium on Zebrafish (Danio rerio) embryos. Journal of Radiation Research, 2016, 57 (4), pp.343-355. ⟨10.1093/jrr/rrv104⟩. ⟨hal-02558457⟩
Collections
IRSN LECO
16 Consultations
0 Téléchargements
