The missing (A, D, r) diagram - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
In this paper we are interested in "optimal" universal geometric inequalities involving the area, diameter and inradius of convex bodies. The term "optimal" is to be understood in the following sense: we tackle the issue of minimizing/maximizing the Lebesgue measure of a convex body among all convex sets of given diameter and inradius. This allows us to completely determine the so-called 2-dimensional Blaschke-Santaló diagram for planar convex bodies with respect to the three magnitudes area, diameter and inradius in euclidean spaces, denoted (A, D, r). Such a diagram is used to determine the range of possible values of the area of convex sets depending on their diameter and inradius. Although this question of convex geometry appears quite elementary, it had not been answered until now. This is likely related to the fact that the diagram description uses unexpected particular convex sets, such as a kind of smoothed nonagon inscribed in an equilateral triangle.
MaxArea.pdf (773.12 Ko) Télécharger le fichier
hal-02559553 , version 1 (12-05-2020)
hal-02559553 , version 2 (06-05-2021)
Alexandre Delyon, Antoine Henrot, Yannick Privat. The missing (A, D, r) diagram. 2020. ⟨hal-02559553v1⟩
Collections
IECLEDP
307 Consultations
204 Téléchargements
