Finite Volume approximation of a two-phase two fluxes degenerate Cahn-Hilliard model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
We study a time implicit Finite Volume scheme for degenerate Cahn-Hilliard model proposed in [W. E and P. Palffy-Muhoray. Phys. Rev. E, 55:R3844R3846, 1997] and studied mathematically by the authors in [C. Cancès, D. Matthes, and F. Nabet. Arch. Ration. Mech. Anal., 233(2):837-866, 2019]. The scheme is shown to preserve the key properties of the continuous model, namely mass conservation, positivity of the concentrations, the decay of the energy and the control of the entropy dissipation rate. This allows to establish the existence of a solution to the nonlinear algebraic system corresponding to the scheme. Further, we show thanks to compactness arguments that the approximate solution converges towards a weak solution of the continuous problems as the discretization parameters tend to 0. Numerical results illustrate the behavior of the numerical model.
CH_FV_CN.pdf (7.5 Mo) Télécharger le fichier
hal-02561981 , version 1 (04-05-2020)
hal-02561981 , version 2 (02-10-2020)
hal-02561981 , version 3 (18-01-2021)
  • HAL Id : hal-02561981 , version 1
Clément Cancès, Flore Nabet. Finite Volume approximation of a two-phase two fluxes degenerate Cahn-Hilliard model. 2020. ⟨hal-02561981v1⟩
175 Consultations
101 Téléchargements
