Projective Dynamics with Dry Frictional Contact - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2020
Projective dynamics was introduced a few years ago as a fast method to yield an approximate yet stable solution to the dynamics of nodal systems subject to stiff internal forces. Previous attempts to include contact forces in that framework considered adding a quadratic penalty energy to the global system, which however broke the simple-constant matrix-structure of the global linear equation, while failing to treat contact in an implicit manner. In this paper we propose a simple yet effective method to integrate in a unified and semi-implicit way contact as well as dry frictional forces into the nested architecture of Projective dynamics. Assuming that contacts apply to nodes only, the key is to split the global matrix into a diagonal and a positive matrix, and use this splitting in the local step so as to make a good prediction of frictional contact forces at next iteration. Each frictional contact force is refined independently in the local step, while the original efficient structure of the global step is left unchanged. We apply our algorithm to cloth simulation and show that contact and dry friction can be captured at a reasonable precision within a few iterations only, hence one order of magnitude faster compared to global implicit contact solvers of the literature.
projectiveDynamicsWithDryFrictionalContactClean.pdf (6.24 Mo) Télécharger le fichier
paper_194_full_res.mp4 (193.57 Mo) Télécharger le fichier
Format : Figure, Image
Format : Vidéo
hal-02563307 , version 1 (05-05-2020)
hal-02563307 , version 2 (11-05-2020)
Mickaël Ly, Jean Jouve, Laurence Boissieux, Florence Bertails-Descoubes. Projective Dynamics with Dry Frictional Contact. ACM Transactions on Graphics, 2020, 39 (4), pp.Article 57:1-8. ⟨10.1145/3386569.3392396⟩. ⟨hal-02563307v2⟩
2042 Consultations
1714 Téléchargements
