Scaling and anisotropic heterogeneities of ocean SST images from satellite data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Oceanic fields display a large variability over large temporal and spatial scales. One way to characterize such variability, borrowed from the field of turbulence, is to consider scaling regimes and multi-scaling properties.
EGU2020-6031_presentation.pdf (9.54 Mo) Télécharger le fichier
hal-02565153 , version 1 (06-05-2020)
François G Schmitt, Hussein Yahia, Joël Sudre, Veronique Garcon, Boris Dewitte, et al.. Scaling and anisotropic heterogeneities of ocean SST images from satellite data. EGU General Assembly 2020, May 2020, Vienna, Austria. ⟨10.5194/egusphere-egu2020-6031⟩. ⟨hal-02565153⟩
125 Consultations
48 Téléchargements
