Foreground-Background Ambient Sound Scene Separation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ambient sound scenes typically comprise multiple short events occurring on top of a somewhat stationary background. We consider the task of separating these events from the background, which we call foreground-background ambient sound scene separation. We propose a deep learning-based separation framework with a suitable feature normaliza-tion scheme and an optional auxiliary network capturing the background statistics, and we investigate its ability to handle the great variety of sound classes encountered in ambient sound scenes, which have often not been seen in training. To do so, we create single-channel foreground-background mixtures using isolated sounds from the DESED and Audioset datasets, and we conduct extensive experiments with mixtures of seen or unseen sound classes at various signal-to-noise ratios. Our experimental findings demonstrate the generalization ability of the proposed approach.
conference_101719.pdf (713.79 Ko) Télécharger le fichier
hal-02567542 , version 1 (07-05-2020)
hal-02567542 , version 2 (25-07-2020)
Michel Olvera, Emmanuel Vincent, Romain Serizel, Gilles Gasso. Foreground-Background Ambient Sound Scene Separation. 28th European Signal Processing Conference (EUSIPCO), Jan 2021, Amsterdam, Netherlands. ⟨hal-02567542v1⟩
450 Consultations
561 Téléchargements
