Rotational forms of Large Eddy Simulation turbulence models: modeling and mathematical theory - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Chinese Annals of Mathematics - Series B Année : 2021
In this paper we present a derivation of a back-scatter rotational Large Eddy Simulation model, which is the extension of the Baldwin and Lomax model to non-equilibrium problems. The model is particularly designed to mathematically describe a fluid filling a domain with solid walls and consequently the differential operators appearing in the smoothing terms are degenerate at the boundary. After the derivation of the model, we prove some of the mathematical properties coming from the weighted energy estimates and which allow to prove existence and uniqueness of a class of regular weak solutions.
Rotational_LB_V5.pdf (348.54 Ko) Télécharger le fichier
hal-02569244 , version 1 (11-05-2020)
Luigi C. Berselli, Roger Lewandowski, Dinh Duong Nguyen. Rotational forms of Large Eddy Simulation turbulence models: modeling and mathematical theory. Chinese Annals of Mathematics - Series B, 2021, 42 (1), pp.1-24. ⟨10.1007/s11401-021-0243-z⟩. ⟨hal-02569244⟩
153 Consultations
155 Téléchargements
