Robust Lasso-Zero for sparse corruption and model selection with missing covariates - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
We propose Robust Lasso-Zero, an extension of the Lasso-Zero methodology [Descloux and Sardy, 2018], initially introduced for sparse linear models, to the sparse corruptions problem. We give theoretical guarantees on the sign recovery of the parameters for a slightly simplified version of the estimator, called Thresholded Justice Pursuit. The use of Robust Lasso-Zero is showcased for variable selection with missing values in the covariates. In addition to not requiring the specification of a model for the covariates, nor estimating their covariance matrix or the noise variance, the method has the great advantage of handling missing not-at random values without specifying a parametric model. Numerical experiments and a medical application underline the relevance of Robust Lasso-Zero in such a context with few available competitors. The method is easy to use and implemented in the R library lass0.
descloux_et_al_2020.pdf (432.44 Ko) Télécharger le fichier
hal-02569696 , version 1 (11-05-2020)
hal-02569696 , version 2 (22-03-2022)
Pascaline Descloux, Claire Boyer, Julie Josse, Aude Sportisse, Sylvain Sardy. Robust Lasso-Zero for sparse corruption and model selection with missing covariates. 2020. ⟨hal-02569696v1⟩
248 Consultations
196 Téléchargements
