A continuation method for building invisible obstacles in waveguides - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Quarterly Journal of Mechanics and Applied Mathematics Année : 2021
We consider the propagation of acoustic waves at a given wavenumber in a waveguide which is unbounded in one direction. We explain how to construct penetrable obstacles characterized by a physical coefficient ρ which are invisible in various ways. In particular, we focus our attention on invisibility in reflection (the reflection matrix is zero), invisibility in reflection and transmission (the scattering matrix is the same as if there were no obstacle) and relative invisibility (two different obstacles have the same scattering matrix). To study these problems, we use a continuation method which requires to compute the scattering matrix S(ρ) as well as its differential with respect to the material index dS(ρ). The justification of the method also needs for the proof of abstract results of ontoness of well-chosen functionals constructed from the terms of dS(ρ). We provide a complete proof of the results in monomode regime when the wavenumber is such that only one mode can propagate. And we give all the ingredients to implement the method in multimode regime. We end the article by presenting numerical results to illustrate the analysis.
BeBC20.pdf (2.51 Mo) Télécharger le fichier
hal-02573706 , version 1 (14-05-2020)
hal-02573706 , version 2 (21-12-2020)
Antoine Bera, Anne-Sophie Bonnet-Ben Dhia, Lucas Chesnel. A continuation method for building invisible obstacles in waveguides. Quarterly Journal of Mechanics and Applied Mathematics, 2021, 74 (1), pp.83-116. ⟨10.1093/qjmam/hbaa020⟩. ⟨hal-02573706v2⟩
254 Consultations
104 Téléchargements
