Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Preprints, Working Papers, ...
Exponential integrators for the stochastic Manakov equation
Abstract : This article presents and analyses an exponential integrator for the stochastic Manakov equation, a system arising in the study of pulse propagation in randomly birefringent optical fibers. We first prove that the strong order of the numerical approximation is $1/2$ if the nonlinear term in the system is globally Lipschitz-continuous. Then, we use this fact to prove that the exponential integrator has convergence order $1/2$ in probability and almost sure order $1/2$, in the case of the cubic nonlinear coupling which is relevant in optical fibers. Finally, we present several numerical experiments in order to support our theoretical findings and to illustrate the efficiency of the exponential integrator as well as a modified version of it.
Complete list of metadata
https://hal.inria.fr/hal-02586778
Contributor : Guillaume Dujardin Connect in order to contact the contributor
Submitted on : Friday, May 15, 2020 - 11:35:44 AM
Last modification on : Wednesday, March 23, 2022 - 3:51:28 PM
Links full text
Identifiers
  • HAL Id : hal-02586778, version 1
  • ARXIV : 2005.04978
Collections
Citation
André Berg, David Cohen, Guillaume Dujardin. Exponential integrators for the stochastic Manakov equation. 2020. ⟨hal-02586778⟩
Share
Metrics
Record views
58
