Diffusion-approximation for a kinetic spray-like system with random forcing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
We study a kinetic toy model for a spray of particles immersed in an ambient fluid, subject to some additional random forcing given by a mixing, space-dependent Markov process. Using the perturbed test function method, we derive the hydrodynamic limit of the kinetic system. The law of the limiting density satisfies a stochastic conservation equation in Stratonovich form, whose drift and diffusion coefficients are completely determined by the law of the stationary process associated with the Markovian perturbation.
kinetic_spray_2020.pdf (522.1 Ko) Télécharger le fichier
hal-02612572 , version 1 (19-05-2020)
hal-02612572 , version 2 (02-07-2020)
Arnaud Debussche, Angelo Rosello, Julien Vovelle. Diffusion-approximation for a kinetic spray-like system with random forcing. 2020. ⟨hal-02612572v1⟩
178 Consultations
86 Téléchargements
