On fixed-time stability of a class of nonlinear time-varying systems
Fixed-time stability of a class of nonlinear time-varying systems is investigated using the introduced notions of sub-and sup-homogeneity. These concepts allow the systems (even if they do not admit homogeneous approximations) to be analyzed using the homogeneity of their extensions. Then, finite-time and fixed-time stability properties can be recovered. The proposed stability conditions are not based on Lyapunov arguments. In the last section, an example illustrates the obtained results.
Domains
Automatic Control Engineering
