Soil microbiota influences clubroot disease by modulating Plasmodiophora brassicae and Brassica napus transcriptomes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue BioRxiv Année : 2020
Arnaud Belcour
The contribution of surrounding plant microbiota to disease development has led to the postulation of the ‘pathobiome’ concept, which represents the interaction between the pathogen, the host-plant, and the associated biotic microbial community, resulting or not in plant disease. The structure, composition and assembly of different plant-associated microbial communities (soil, rhizosphere, leaf, root) are more and more described, both in healthy and infected plants. A major goal is now to shift from descriptive to functional studies of the interaction, in order to gain a mechanistic understanding of how microbes act on plant growth and defense, and/or on pathogen development and pathogenicity. The aim herein is to understand how the soil microbial environment may influence the functions of a pathogen and its pathogenesis, as well as the molecular response of the plant to the infection, with a dual‐RNAseq transcriptomics approach. We address this question using Brassica napus and asmodiophora brassicae, the pathogen responsible for clubroot. A time‐course experiment was conducted to study interactions between P. brassicae, two B. napus genotypes, and three soils harboring High (H), Medium (M) or Low (L) microbiota diversities and displaying different levels of richness and diversity. The soil microbial diversity levels had an impact on disease development (symptom levels and pathogen quantity). The P. brassicae and B. napus transcriptional patterns were modulated by these microbial diversities, and the modulations were dependent of the host genotype plant and the kinetic time. The functional analysis of gene expressions allowed the identification of pathogen and plant-host functions potentially involved in the change of plant disease level, such as pathogenicity-related genes (NUDIX effector) in P. brassicae and plant defense-related genes (glucosinolate metabolism) in B. napus.
2020_Daval_bioRkiv_1.pdf (1.66 Mo) Télécharger le fichier
hal-02624824 , version 1 (26-05-2020)
hal-02624824 , version 2 (14-01-2021)
Paternité
  • HAL Id : hal-02624824 , version 1
  • PRODINRA : 496535
Stéphanie Daval, Kévin Gazengel, Arnaud Belcour, Juliette Linglin, Anne-Yvonne Guillerm-Erckelboudt, et al.. Soil microbiota influences clubroot disease by modulating Plasmodiophora brassicae and Brassica napus transcriptomes. BioRxiv, 2020. ⟨hal-02624824v1⟩
226 Consultations
163 Téléchargements
