Abstract : A general synchronization scheme for the common dynamics of Persidskii systems is presented in this paper. The conditions of output stability of the closed-loop systems and their synchronization are established in the form of linear matrix inequalities (LMI). An example of Chua's circuit is considered for examining the effectiveness of our proposed results. A designing method of feedback gains is also introduced.
