Estimation of Frequency for AM/FM Models Using the Phase Vocoder Framework - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Journal Articles IEEE Transactions on Signal Processing Year : 2008
This paper proposes an extension of the applicability of phase-vocoder-based frequency estimators for generalized sinusoidal models, which include phase and amplitude modulations. A first approach, called phase corrected vocoder (PCV), takes into account the modification of the Fourier phases resulting from these modulations. Another approach is based on an adaptation of the principles of the time-frequency reassignment and is referred to as the reassigned vocoder (RV). The robustness of the estimation against noise is studied, both theoretically and experimentally, and the performance is assessed in comparison with two state-of-the-art algorithms: an unmodified version of the reassignment method and a quadratically interpolated fast Fourier transform method (QIFFT). Index Terms-AM/FM model, frequency estimation, phase vocoder.
Dates and versions
hal-02652652 , version 1 (29-05-2020)
Identifiers
Cite
Michaël Betser, Patrice Collen, Gael Richard, Bertrand T. David. Estimation of Frequency for AM/FM Models Using the Phase Vocoder Framework. IEEE Transactions on Signal Processing, 2008, 56, ⟨10.1109/TSP.2007.906768⟩. ⟨hal-02652652⟩
30 View
0 Download
Share
