Stochastic representation of mesoscale eddy effects in coarse-resolution barotropic models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Ocean Modelling Année : 2020
A stochastic representation based on a physical transport principle is proposed to account for mesoscale eddy effects on the evolution of the large-scale flow. This framework arises from a decomposition of the Lagrangian velocity into a smooth in time component and a highly oscillating term. One important characteristic of this random model is that it conserves the energy of any transported scalar. Such an energy-preserving representation is tested for the coarse simulation of a barotropic circulation in a shallow ocean basin, driven by a symmetric double-gyres wind forcing. The empirical spatial correlation of the random small-scale velocity is estimated from data of an eddy-resolving simulation. After reaching a turbulent equilibrium state, a statistical analysis of tracers shows that the proposed random model enables us to reproduce accurately, on a coarse mesh, the local structures of the first four statistical moments (mean, variance, skewness and kurtosis) of the high-resolution eddy-resolved data.
sbve_ocemod.pdf (5.24 Mo) Télécharger le fichier
hal-02666147 , version 1 (31-05-2020)
Werner Bauer, Pranav Chandramouli, Long Li, Etienne Mémin. Stochastic representation of mesoscale eddy effects in coarse-resolution barotropic models. Ocean Modelling, 2020, 151, pp.1-50. ⟨10.1016/j.ocemod.2020.101646⟩. ⟨hal-02666147⟩
273 Consultations
197 Téléchargements
