Equilibrium Configurations For Nonhomogeneous Linearly Elastic Materials With Surface Discontinuities - Inria - Institut national de recherche en sciences et technologies du numérique
Article Dans Une Revue Annali della Scuola Normale Superiore di Pisa, Classe di Scienze Année : 2023
We prove a compactness and semicontinuity result that applies to minimisation problems in nonhomogeneous linear elasticity under Dirichlet boundary conditions. This generalises a previous compactness theorem that we proved and employed to show existence of minimisers for the Dirichlet problem for the (homogeneous) Griffith energy.
MinimisationGSBDpRevisedBN.pdf (473.64 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-02667936 , version 1 (31-05-2020)
hal-02667936 , version 2 (07-10-2021)
Antonin Chambolle, Vito Crismale. Equilibrium Configurations For Nonhomogeneous Linearly Elastic Materials With Surface Discontinuities. Annali della Scuola Normale Superiore di Pisa, Classe di Scienze, 2023, XXIV (3), pp.1575-1610. ⟨10.2422/2036-2145.202006_002⟩. ⟨hal-02667936v2⟩
152 Consultations
103 Téléchargements
More
