Summarizing complex asynchronous Boolean attractors, application to the analysis of a mammalian cell cycle model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Biological regulatory networks can be efficiently modeled by asynchronous Boolean networks. In such networks, asymptotic dynamical behaviors are captured by asynchronous attractors, which are strongly connected graphs that may include multiple intertwined cycles. If it can be easily computed, comparing such a complex graph with a biological phenomenon may become rapidly cumbersome. In this paper, we propose to use the concept of summary graph to help the analysis of asynchronous attractors, by projecting them on partitions of the state space. The method is applied to a Boolean model of the mammalian cell cycle, for which we propose a suitable partition based on the cycle's phases. Thanks to our approach, we were able to isolate the expected succession of the phases.
Fichier non déposé
hal-02737659 , version 1 (02-06-2020)
  • HAL Id : hal-02737659 , version 1
  • PRODINRA : 480892
  • WOS : 000490488301114
Ousmane Diop, Laurent Tournier, Vincent Fromion. Summarizing complex asynchronous Boolean attractors, application to the analysis of a mammalian cell cycle model. European Control Conference 2019, Jun 2019, Naples, Italy. ⟨hal-02737659⟩
50 Consultations
0 Téléchargements
