Adaptation to the Range in $K$-Armed Bandits - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
We consider stochastic bandit problems with $K$ arms, each associated with a bounded distribution supported on the range $[m,M]$. We do not assume that the range $[m,M]$ is known and show that there is a cost for learning this range. Indeed, a new trade-off between distribution-dependent and distribution-free regret bounds arises, which, for instance, prevents from simultaneously achieving the typical $\ln T$ and \smash{$\sqrt{T}$} bounds. For instance, a \smash{$\sqrt{T}$} distribution-free regret bound may only be achieved if the distribution-dependent regret bounds are at least of order \smash{$\sqrt{T}$}. We exhibit a strategy achieving the rates for regret indicated by the new trade-off.
Hadiji-Stoltz--Range-2020.pdf (2.21 Mo) Télécharger le fichier
hal-02794382 , version 1 (05-06-2020)
hal-02794382 , version 2 (10-11-2020)
hal-02794382 , version 3 (09-06-2022)
Hédi Hadiji, Gilles Stoltz. Adaptation to the Range in $K$-Armed Bandits. 2020. ⟨hal-02794382v1⟩
277 Consultations
164 Téléchargements
