Guaranteed lower bounds on eigenvalues of elliptic operators with a hybrid high-order method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Numerische Mathematik Année : 2021
This paper introduces a novel hybrid high-order (HHO) method to approximate the eigenvalues of a symmetric compact differential operator. The HHO method combines two gradient reconstruction operators by means of a parameter $0<\alpha<1$ and introduces a novel cell-based stabilization operator weighted by a parameter $0<\beta<\infty$. Sufficient conditions on the parameters $\alpha$ and $\beta$ are identified leading to a guaranteed lower bound property for the discrete eigenvalues. Moreover optimal convergence rates are established. Numerical studies for the Dirichlet eigenvalue problem of the Laplacian provide evidence for the superiority of the new lower eigenvalue bounds compared to previously available bounds.
HHO_EVP_final.pdf (543.11 Ko) Télécharger le fichier
hal-02863599 , version 1 (10-06-2020)
hal-02863599 , version 2 (07-10-2020)
hal-02863599 , version 3 (28-05-2021)
hal-02863599 , version 4 (03-08-2021)
Carsten Carstensen, Alexandre Ern, Sophie Puttkammer. Guaranteed lower bounds on eigenvalues of elliptic operators with a hybrid high-order method. Numerische Mathematik, 2021, 149, pp.273-304. ⟨10.1007/s00211-021-01228-1⟩. ⟨hal-02863599v4⟩
323 Consultations
222 Téléchargements
