A local damage model of concrete structures by a variational approach including tension and compression mechanisms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
The present work aims at providing a numerical method to estimate the damage of a concrete structure, under the load of an avalanche-type natural event. Using the Francfort and Marigo damage model, we begin by validating the model in a 1--D configuration by analytical and numerical calculus. Moreover, as concrete has very different behaviour in tension and compression, we then introduce a tension-compression formulation in a 2--D configuration within the variational approach to damage. Considering a non-vanishing resulting Young modulus and minimizing the total energy, including the energy released by damage, provides us with the damage state during the load, without resorting to non-local formulation. We present some validation simulations such as three-point flexural test. Finally, we show realistic simulations of bending of the structure under the load of an avalanche and the resulting damaged state.
main.pdf (1.78 Mo) Télécharger le fichier
hal-02864665 , version 1 (11-06-2020)
  • HAL Id : hal-02864665 , version 1
Céline Acary-Robert, Vincent Acary. A local damage model of concrete structures by a variational approach including tension and compression mechanisms. 2020. ⟨hal-02864665⟩
118 Consultations
73 Téléchargements
